Artikel-ID : 00129526 / Zuletzt geändert : 11/03/2025Drucken
    Ein mobiles Gerät kann mit dem Mini Hi-Fi-System nicht geladen werden.
    Check the following if the mobile device cannot be charged using the Mini Hi-Fi component system:
    • Make sure the device is securely connected to the Mini Hi-Fi component system and that the system is turned on and working properly.
      NOTE: When the Mini Hi-Fi system enters standby mode, the mobile device may stop charging. Disable the Automatic Standby function to prevent the Mini Hi-Fi component system from going into standby mode automatically.
    1. Press OPTIONS
    2. Select AUTO STBY
    3. Select OFF
    • Set the Mini Hi-Fi system to USB function.
    NOTE: The mobile device might not be compatible with the Mini Hi-Fi component system. While most mobile devices should charge, Sony cannot guarantee that the system will be able to charge any device.
